It is currently 22 Sep 2026, 04:45
Hi - New Member
A great place to make your first posting.
s_elias
Hi - New Member
Post30 Jan 2013, 09:19
Hello,
I'm a new member and have been "hooked" on collecting digital watches (and mechanical as well ;)
I have a few bulova's, hamilton's in various needs of TLC, and others to experiment with. Additionally I have an LED Pen that I need help with getting the setting going, it's a qualitron. If some one can scan the original instructions and let me know what size batteries it takes I would appreciate it.
I have many questions which I'll post over the next few weeks as well :) Maybe one day I can answer a few as well :)
I have a technical background, so I what to learn as much as possible from the masters including wire bonding by hand.
btw - Is there a database of modules somewhere that contains pictures and various models?
Thanks !
Re: Hi - New Member
Post30 Jan 2013, 17:10
Hi Elias, and welcome to the board from us moderators.
Shoot and we will help you and don't forget to post shots of your watches..we love to see them
I also have Qualitron led pens as you all ready have read..just open it like you put new batts in and push the inside towards the batt.. that way you can set it.
Have fun
s_elias
Re: Hi - New Member
Post30 Jan 2013, 17:35
Thanks Kasper,
I've been learning alot just reading some of the old threads from you, old joe, and others.
One note on the pen, it is lighting up - Yah ! - however I think I'm missing a part / battery cover.
When I open it up, the only item covering the batteries is a spring :(
I think at one time there may have been a cover with a hole over the spring to keep everything in place. Can you confirm?
Also do you have any leads on replacement ink refills for these? I think the length is ~35mm and 3mm wide.
Return to Members of DWF
