Looking for 25mm led module
jupooo
Post10 Jan 2012, 17:04
I am looking for a led module for my tissot led watch (this type http://www.ledwatches.net/photo-pages/tissot3.htm).
I have been looking around for some time now with no success for the correct Nortec module.
As you can tell from the pictures of the module there is a little piece sticking out to prevent the module rotating in the case.
Now I am at a point where I would like to ask if someone has a working led module (25mm) maybe I can find a solution to prevent it from rotating in the case.
Thanks,
: Looking for 25mm led module
Post12 Jan 2012, 14:25
Does this watch has buttons at 1 and 3 o clock only? If yes I might help you.
jupooo
Post13 Jan 2012, 09:37
Hello,
Thank's for your reply.
You are correct, at the 1 position for time and 3 for setting.
