Adjusting button switch for 0654 wanted
albertofenini
Post28 Oct 2012, 19:50
Dear All, I've been so lucky to found a new old stock module for my 0654.
Someone of you may remember that in the past I had destroyed the original non working module while washing it :oops: ,
then I had found another unit with also a non working module but a working lcd and now the nos module :-D
In order to finish my project I need the Adjusting button switch, which is the same size of that from a 0624
Here is a picture of the module I'm restoring
and a picture of the button I need (this is from a 0624) which is basically the center button
that you pull out and push in when you want to set the time.
Thanks in advance to everyone for help and support,
Alberto
