24mm LED module needed
peachykeen
Post25 Sep 2013, 20:25
Hi guys,
I'm searching for a 24mm LED module. Command button at 2, set button at 3. The set-button is recessed by about 1mm, whereas the command button is mounted flush with the interior cutout of the case.
Here a few pictures of what I found inside the case. Completely dead and with no indication whatsoever about the manufacturer:
peachykeen
Re: 24mm LED module needed
Post23 Oct 2013, 10:27
bump
