It is currently 29 Apr 2026, 10:12
Seiko world time lcd A239
CompuChron2
Post09 Dec 2006, 03:32
I have a nice SEIKO world time like this one:
http://www.sigma957.org/bilder/A239_1.jpg
It works but the screw on the back that hold the batterie is missing.
Does any one of you got this part?
The eye of the master,
L'oeil du ma?tre
Re: Seiko world time lcd A239
Post10 Dec 2006, 07:20
Olivier - give us a shot of the back side....of the WATCH man,
of THE WATCH!!! :oops:
CompuChron2
Post11 Dec 2006, 00:46
Diameter of the hole
inner 10 mm
outer 12 mm
Thanks guys!
L'oeil du ma?tre
CompuChron2
Post18 Dec 2006, 21:12
Thanks to T-bird,
the part is found!
End ofthe thread...
L'oeil du ma?tre
CompuChron2
Post04 Jan 2007, 00:45
I received the part this morning and it's too big :cry:
So I'm still lloking for that damn SEIKO battery hatch!
L'oeil du ma?tre
redled
Post08 Jan 2007, 16:07
Please accurately measure the diameter of the circle at the surface of the back, i'll check if I have it.
Post08 Jan 2007, 16:40
Guys, that is not a screw thread button, it is a 1/4 turn locker - note the tabs inside the hole and the markings on the back.
CompuChron2
Post08 Jan 2007, 17:29
Accurate diameter of the hole 12mm at most
10 mm in the inside
L'oeil du ma?tre
CompuChron2
Post20 Jan 2007, 22:37
Just let you know that I'm still searching for the 1/4 turner locker...
L'oeil du ma?tre
seikoric
Post01 Feb 2007, 00:12
i might have one, i'd have to check, whats it worth ;)
Cheers, Ric
CompuChron
Post26 Feb 2007, 09:24
Hi Ric,
did you find one battery plug for my seiko?
I'm still searching!
let me know
Olivier
CompuChron
Post23 Apr 2007, 21:34
Finally found it in a lot of watch from the same watch with a broken glass.It is on its way home!
CompuChron
Post26 Apr 2007, 21:34
I received it but I have another "problem" , the trash watch is working too , so I still need one plug!
Furthemore , I can't set it , can someone help me?
When I enter into the setting mode , I can't "go" to setting the time and date...
Users browsing this forum: Google [Bot] and 48 guests
