It is currently 20 Jan 2026, 00:20
Seting a times SSQ???
CompuChron2
Post11 Jan 2007, 12:16
I have an old TIMEX SSQ (thanks embelton) which I can't figure out how to set.
It has 2 buttons , one on the left for light , the one one the right is for command (date and seconds).
There is NO setting button.
I've tried many combinations on these 2 buttons , but can't go into setting mode.
Any idea :?:
The eye of the master,
L'oeil du ma?tre
CompuChron2
Re: Seting a times SSQ???
Post11 Jan 2007, 12:19
looks like this:
L'oeil du ma?tre
Post11 Jan 2007, 13:49
Hey. You've got to gently twist the buttons around until the flat side is facing you then quickly press the right button 4 times quickly (I think it's 4 times -you may have to experiment a bit...). this should put it into setting mode.
Cheers. DB
Post11 Jan 2007, 17:55
Most of those Timex's are in setting mode as soon as you turn the flat out ...kind of tricky turning them back without pushing in. :P
Higgie
Site Sponsor
Site Sponsor
Post11 Jan 2007, 20:49
Just rotate the right button 180? ( flat side up )
And you can set the time.
When you rotate the left button, you will reset the watch.
CompuChron2
Post13 Jan 2007, 11:47
Thanks everybody.
It was easy to set with all this information:
turn the light command button until the flat part faces you , and it's in setting mode.
The other buttons reset the watch,you were right.
it's a bit ugly , isn't it?
L'oeil du ma?tre
