It is currently 19 Apr 2026, 20:54
Texas Time Inc.
Texas Time Inc.
Post06 Jun 2015, 21:01
Found this today :scratch:
No pushers, sealed tight, no way to set time from outside of case.
PG101
Re: Texas Time Inc.
Post07 Jun 2015, 00:00
Is there any play on the case-back? I mean, can you push it in with your finger once it's closed?
There looks to be a type of pusher on the cover plate, that matches up with that black "dot" on the back of the module.
I suspect that this button may be depressed by pushing the case-back with your thumb? I suppose you'd need to get it running first though?
Anyway, just a thought...
Re: Texas Time Inc.
Post07 Jun 2015, 00:11
Nope, does not press in. Nothing to set the time from outside the case :scratch:
elceedee
Re: Texas Time Inc.
Post08 Jun 2015, 23:26
Setting the watch with magnets (like the pulsars) might be an option?
Re: Texas Time Inc.
Post09 Jun 2015, 09:55
Perhaps you set the module before putting into the case ?
I notice you bolt the battery down so that the module can remain powered up outside of the case.
Are there setting tabs/pushers on the side of the module ?
Re: Texas Time Inc.
Post09 Jun 2015, 14:08
No contacts on the sides of module. When battery is in place, there's only 2 contacts visible. They are next to the trimmer on front.
Definitely different, I've never seen one like it.
Has anyone ever heard of Texas Time Inc.?
Re: Texas Time Inc.
Post09 Jun 2015, 17:17
never seen before..interesting one.
Users browsing this forum: Google [Bot] and 61 guests
