It is currently 25 Oct 2026, 16:06
JULES JURGENSEN OPTCOM I OPTEL w/ FE Display
coconutman351
Post26 Dec 2019, 20:50
Just acquired a Jules Jurgensen OPTCOM I. Looks like it's operational but the Field Effect LCD display is dim probably due to its age. This model has the flashing display module presumably to extend the battery life. Will send more pictures when I receive it otherwise the case appears to be in great shape. If the FE LCD display is dim is there a way to revive it? If I also were to swap this FE module out this module with another Optel DSM module would it be difficult to do and is it a 1:1 swap?
resized the photos, originals were way too large.
coconutman351
Re: JULES JURGENSEN OPTCOM I OPTEL w/ FE Display
Post10 Jan 2020, 07:21
Updated this watch with a DSM 5424F LCD module. Does anyone know the best way to remove the crystal? I'm not even sure if it's a mineral crystal glass or acrylic plastic. I wanted to restore the brush marks on the flat surface around the crystal.
thank you!
Robert
Post13 Jan 2020, 17:05
Its a mineral Crystal...make it warm and try to push it inside out. Or find something as big as the glass to give equal pressure all over when you push it out.
coconutman351
Post13 Jan 2020, 20:29
Thank you Kasper for that tip. So the mineral crystal is mounted on from the outside just like the Pulsar LED cases? There is the inside frame that houses the Opticom 1 bezel so essentially I would need to warm up the outside face to soften up the glue and gently push the crystal outward from the inside of the case correct?
thank you!
Robert
Post15 Jan 2020, 10:24
i can not tell you it's inside out or reverse...if you get the module out..it,s easy to see the direction to push. :-D
coconutman351
Post15 Jan 2020, 18:43
Ok thanks Kasper, will post some photos as well when I remove the case front.
