It is currently 23 Oct 2026, 19:29
Seiko S771 EPD E-Ink Watch - batteries
Plato
Post26 Jan 2018, 14:55
Good day to all of you
I have had this watch for several years now.. bought it from a member on here. It is a lovely watch as a daily beater but the charge has gone completely for some time now and no amount of sunlight will revive it.
I took off the back and it has a CR1616f cell. As the watch recharges I assume this is a rechargeable cell.
I have a spare CR1616 in my battery box and that has gone into the watch without a fuss, and it works. However, is it the correct cell? It doesn't have the f suffix and I don't know if it will recharge. If its a non-rechargeable cell, will the attempts of the watch to recharge it cause a problem (i imagine the cell exploding on my wrist...).
Any advice welcome.
Re: Seiko S771 EPD E-Ink Watch - batteries
Post28 Jan 2018, 16:32
have the same issue..i'm always at home in my shop, so it cannot take enough juice during the day and slowly dies. Just buy a new rechargeable cell and you are good to go. If i put the watch near the window all day..it's just enough to stay awake :-D
Plato
Post28 Jan 2018, 17:20
Indeed my friend... I am wondering whether to just replace the cheap cell as each runs out. Ill see how long this one lasts.
They only cost a few euros maximum. So then the cost will be negligible.. As long as the cell doesn't have any bad effects on the watch.. it isnt a rechargeable at that price and the seiko website states that they use special batteries which I can't seem to find.
I'm let your know how the experiment goes!
Post28 Jan 2018, 20:59
If the recharge system functions then yes, the cell can react badly. Most likely by swelling and leaking. There is an argument that a very slow trickle charge to an alkaline will result in recharging of the cell but the physical structure and internal chemical make up were not designed for recharging. Lithium non-rechargeable batteries do not like recharging and can result in a runway chemical reaction destroying the Battery and probably the watch module. Lithium batteries HATE two things:
1). HEAT. (So charging a non rechargeable lithium is lethal to the Battery.
2) deep drain with no recharge (I.e. use until dead then recharge attempt)
My Star Wars EPD recharge circuit failed at the 3 year mark. The watch went to Seiko japan who replaced the charging circuit with a newer mark ‘2’ version 3 years ago and to my surprise, for free, except shipping. Holds a perfect full charge always now. Of course I leave it near the window when not in use, not at the window and never let it cycle to dead.
I would hold off, find a rechargeable 1616 lithium battery OR cut the recharge circuit wire for a permanent solution and only buy non rechargeable batteries. Careful as the recharge circuit may be involved with current transfer to the watch.
Amazon Canada (assume USA also) https://www.amazon.ca/Casio-CTL1616-Genuine-Rechargeable-Battery/dp/B0080GQBTU
Geoff
Plato
Post23 Dec 2018, 19:29
Update..
I have been using the watch with a non rechargeable battery. So far no problems at all and it's working wonderfully. No overheating or damage to the module.
I suspect the charging circuit is not enough to damage the battery.
as an aside I never see these for sale now any idea what it's worth on the open market. I have a better example and may sell.
Cheers
Return to Modern Digitals
