It is currently 17 Mar 2026, 04:16
Ventura Alpha Backlight issue
jimster
Post23 Nov 2025, 03:15
Greetings,
I just did a battery change on my Alpha. Everything is fine. Set the time, date and went to check the backlight. When I pushed the backlight button the screen went black. I could not retrieve the display so I removed the battery, reinstalled it and reset the time and date. All is good but I haven't touched the backlight again.
Any thoughts?
Thanks,
Jim
sbradley02
Re: Ventura Alpha Backlight issue
Post01 Dec 2025, 17:33
jimster wrote:Greetings,
Any thoughts?
Thanks,
Jim
I have a similar issue, see my post just now. Mine is more severe as I can't use the watch at all since I can't set the time. I suspect that no one actually works on these watches nowadays.
jimster
Post04 Dec 2025, 20:57
Have you tried Swiss Watch Service, Jacques Reymond? I haven't used him in years but he repaired a Sparc for me. He's in Utah.
(801) 582-0731.
