It is currently 06 May 2024, 20:00
Gold Plating tips?
CompuChron2
Gold Plating tips?
Post19 Mar 2006, 03:07
Hi guys,
does anyone makes gold plating at home for restoring worn bands/cases?
How?
Seer Taak
Re: Gold Plating tips?
Post19 Mar 2006, 14:05
Zoesandra, a dwf member, used to offer this service on ebay for ~$100. Dont know what depth of plate it was though, I suspect it would be very thin?
You could also do a quick google for something like 'gold plating solution'. I did one and got loads of links like this. Mind you some, like this link use cyanide, so be very carefull when you use it, but others are much safer.
CompuChron2
Post19 Mar 2006, 14:20
I found that:
http://www.caswellplating.com/kits/plugnplate.htm
Anyone goldplates at home???
dot matrix
Post20 Mar 2006, 23:52
I used to do gold electroplating at home - not of watches, though, just of jewelry (rings) and coins.
Yes, the solution is cyanide based, so don't inhale the fumes or do the plating inside. I did it outside, sat upwind, and wore rubber gloves. Instant death can be the result if you're not careful.
Also, gold is a very soft metal so the plating is not very durable.
Post21 Mar 2006, 01:03
There is a plating shop where I work they have cayanide antidote at hand just incase someone gets a dose of this stuff.
It's very very nasty...
No, they don't do gold before anyone asks.!!!
zoesandra
Post25 Apr 2006, 10:59
If you still need the gold plate i am still plating. i sent you a PM. zoesandra
