It is currently 02 Mar 2026, 02:23
Bulova Sideview timekeeping
Seer Taak
Post16 Sep 2006, 11:13
I have a Bulova sideview with a timekeeping problem. Does anyone have any ideas? The problem's slightly different from the Bulova Computron problem digibloke metioned, so I thought i'd start a new thread.
Like digibloke's, my watch keeps great minutes, and date, but some time after I set it, the hours jump forward. I set it last night at 18:00, but by the time it should have been some where in the 19:00's it was actually in the 12:00's? The problem is different from digibloke because after the hours have leapt forward they continue to progress in a regular, not random, way as each hour passes, e.g. 12 to 1 to 2 etc.
The module is a 24hr, single button type, if that makes any difference?
Thanks for any suggestions :)
Re: Bulova Sideview timekeeping
Post16 Sep 2006, 18:21
If you don't feel like popping all the way open, pop out both batterys and put a vacuum cleaner to one hole and give it a few seconds of gentle draft thru the other hole. Sometimes people have used steel wool or other conductive stuff on the watch and you have a minor short that sets off setting mode. Or do a close visual inspection. Sucks, I have one on my desk right now (Sharp brand) that does the same thing: very randomly, like every few days to 2 weeks, it falls back 30-40 minutes and then resumes keeping FLAWLESS time. :x And I've gone over it several times now, waaaay more effort than it will ever be worth.
