It is currently 11 May 2024, 22:19
Strange problem ...opinions??
CompuChron2
Post28 Nov 2006, 17:38
Hi ,
I have a nos gruen led watch which seems to work perfectly, set well , all functions are displayed when buttons are pushed : date and seconds , the seconds advance at a normal pace when pusher is remained pushed (about 1sec/sec!)
BUT , the times doesn't move at all unless you keep your finger on the buttons showing the seconds.
I.E if you set it at 11:45 , you come back one hour later it's still 11:45 and the seconds haven't advance.They only move when the button is pressed.
Do you have any idea in what is involved in that?
Anyone experienced that already?Olivier
The eye of the master,
L'oeil du ma?tre
CompuChron2
Re: Strange problem ...opinions??
Post21 Dec 2006, 10:25
up up up!
L'oeil du ma?tre
Post22 Dec 2006, 00:58
My guess is it has a Frontier module(yes/no?), with the little spring coming out of the back of the module...either the spring isn't touching the back, or not making contact with the module. Funny system they have.
Majestyk
Post22 Dec 2006, 08:37
Yeah, it's not getting enough voltage. The only thing that's giving it enough voltage to display and keep time is the steel button touching the contact. Can you post a photo of the module?
CompuChron2
Post30 Dec 2006, 00:44
I've cleaned the battery contact and now it seems to work perfectly.
Thanks You all!
L'oeil du ma?tre
CompuChron2
Post30 Dec 2006, 01:01
here it is:
L'oeil du ma?tre
redled
Post09 Jan 2007, 17:01
Cool, i've seen that problem, and now I know what causes it, thanks guys!
Users browsing this forum: No registered users and 44 guests
