LCD Display Keeps Flashing On & Off
tycooke
Post14 Apr 2007, 00:40
My Bulova LCD watch display works okay but keeps flashing on and off. Any info on fixing this problem would be appreciated.
Thanks,
Ty.
seikoric
re: LCD Display Keeps Flashing On & Off
Post14 Apr 2007, 04:40
prob needs a new bat
Cheers, Ric
tycooke
Post16 Apr 2007, 02:24
Hi Ric,
Battery is new.
Ty.
redled
Re: re: LCD Display Keeps Flashing On & Off
Post16 Apr 2007, 09:51
tycooke wrote:Hi Ric,
Battery is new.
Ty.
You know that and I know that but does the watch know that? In other words, try cleaning all the battery contacts needless to say, carefully.
Post16 Apr 2007, 11:07
repeated thread?
if it's a 1977 (N7) Bulova with a japanese (likely Seiko) module then the fault might be caused by a short sometimes caused by an improper battery.
I installed a correct battery but it turned out that they make this battery in two versions - flat negative top and also with a nipple on top.
This nipple raises the battery by a fraction but solves the problem.
hope this helps.
tycooke
Post16 Apr 2007, 23:02
I fixed the problem. The negative battery terminal on module had some corrosion where it makes contact with battery. After cleaning with alcohol and Q-tip the display stopped flashing. Thanks for helping.
Ty.
