Novus LED Watch Display Problem
tycooke
Post28 May 2007, 19:42
My Novus LED men's watch has worked okay untill today. When I pressed button to display time the display only showed one number segment like 3. The batteries were low so I changed them. Still have same problem. Any ideas on what could be the problem?
Tyrone.
re: Novus LED Watch Display Problem
Post28 May 2007, 19:48
Oscillator crystal
Post01 Jun 2007, 20:49
you're right Ed, but what next if the swap doesn't help?
I have a few of such National Semiconductor modules.
repairing a track was the solution on one occasion. what are other options?
Majestyk
Post02 Jun 2007, 07:44
There's not much you can do with those if replacing the QC doesn't work. If you heat it up and it works, then it could be a problem within the IC or if you're lucky, a bad solder joint in an area that is accessible...That includes "repairing a track" if I get your lingo. :)
M
