Pulsar question
ckracing
Pulsar question
Post11 Mar 2008, 17:41
I have a SS PII, I installed fresh batteries(357 w/spcers). Set the time everything worked for about 36 hours. Then the display is stuck at 2. 4
removed batteries.
Any idea of what the problem is?
Can it be fixed and if it can what is the cost?
thanks
Charles
: Pulsar question
Post12 Mar 2008, 08:40
Hi Charles.
The 2. 4 you describe looks like the date display you'd get from a P3 module. It may have a replacement P3 module installed (in which case the date display would never normally be activated). See the image at the bottom of this page:
http://crazywatches.w.interia.pl/photo/ ... _tech.html
Remove the module and check if there's a reed switch on both sides (glass tubes). If there is a reed switch on the left side of the module, then it's probably "stuck on" for some reason. Check if there's a short across the switch. If it is shorted, then you could try putting a magnet against it a few times to try to release it. Otherwise you could cut one of the ends that connects to the module.
ckracing
: Pulsar question
Post12 Mar 2008, 15:28
Thanks Andrew, I appreciate the advice. I added your website to my favorites. Very nice website.
Charles
: Pulsar question
Post13 Mar 2008, 04:51
No problem.
it's not my website, it's "azimuth_pl" 's webiste.
He may be able to fix your watch if you don't have any luck.
