It is a well known phenomena that quartz crystals tend to slow to a degree and then stabilize until such time as they fail. When purchasing quartz crystals, look for those with the lowest "ageing" numbers,10pppm or lower, and the widest temperature range(although, accuracy may be quite off at the end of their range). The oldest,early crystals were cut and ground pieces of particular quartz'(primarily silicon dioxide), the modern ones are generally lab grown and formed in sheets and cut or formed right on the electrodes that make the electrical connections to them. Back in the day many manufacturers burned-in(ran) their crystals for a few days to get rid of some of the initiall decline, so their watches could be adjusted before leaving the factory, to a fairly high accuracy. Others explained that their watches needed to be adjust a few times during the first few months to bring them into the claimed accuracy. And others just figured it was close enough. Many of us set our watches a minute fast if it tends to run slow and figure when it bothers us enough we will re-set it.
Even if you set it with a timing machine, once on someones arm it is probably 15-20 degrees(Fahrenheitt) warmer, which will tend to throw the timing off marginally.
http://www.retroleds.com -
Sales of vintage LED, LCD, analog watches,
parts and gadgets -
repair tutorials & tips
