It is currently 02 Mar 2026, 09:57
Suggestions for case screw tool
Disector
Post26 Sep 2010, 05:27
Hey guys,
I would take suggestions on brands for a good #00 Phillips screwdriver for use on my (4) Majestyk watches.
I browsed around and it seems about all I can find look like the cheap junk you'd find at home depot with the pressed on spinning end cap.
I don't want a $20 screwdriver, but I don't want soft junk either.
Thoughts?
: Suggestions for case screw tool
Post26 Sep 2010, 17:09
For a walk-in store, Radio Shack carries a "good to better" line of smaller hand tools.
Disector
Post16 Oct 2010, 23:04
I got this one.
http://www.amazon.com/gp/product/B003ES5M1M
Seems to be top notch and was affordable. Too bad 2 of the screw heads were pretty much already stripped out. At least they weren't too tight!!
Post16 Oct 2010, 23:10
I'm curious if the end on yours rotates. Those "spinning caps" actually allow for pressure to be maintained downward (cap against the palm) whilst keeping the screwdriver parallel to the screw, all while turning with two fingers. :-)
Disector
Post17 Oct 2010, 06:07
Yes the end does spin and the bit seems to fit the unmangled screw heads well.
Users browsing this forum: No registered users and 57 guests
