It is currently 03 Jul 2026, 09:25
HAVE A COMPUCHRON TWO SCREW CAP BATTERY HELP
1lumhechati
Post21 Oct 2010, 16:47
HAVE A GOLD FILLED COPMUCHRON LARGE ROUND RED CRYSTAL 2 SCREW DOWN LIDS FOR BATTERY ON INSIDE THE LIN HAS A STAMP WITH A 3 AND 75 UNDER IT. A STICKER ON THE PASTIC MOUNT WITH A1.76 ON IT HAS BUTTON AT THE 8 AND AT THE 2 AND AT THE 3 HELP WITH POSSIBLE DATE AND MODEL ANY THING TO LOOK FOR WILL HELP,what would this be made and value,works perfect an http://yfrog.com/87p10100260010j http://img44.imageshack.us/i/p10100280012.jpg/ http://img836.imageshack.us/i/p10100270011.jpg/ http://img219.imageshack.us/i/p10100340018.jpg/ http://img190.imageshack.us/f/p10100230007.jpg/ http://img641.imageshack.us/f/p10100410025.jpg/
Re: HAVE A COMPUCHRON TWO SCREW CAP BATTERY HELP
Post21 Oct 2010, 18:42
1lumhechati wrote:ANY THING TO LOOK FOR WILL HELP
A photo would help identifying your watch.
1lumhechati
Post25 Oct 2010, 12:16
HERE;S PICTURE'S OF THIS WATCH,CAN SOMEONE GIVE ME SOME INFO ON IT-DATE,SCARCE/COMMON,MAYBE VALUE OR GEN.INFO. WORKS PERFECT THANK YOU.AND I'D LIKE TO SELL IT/NEED SOME INFO.
JESUS IS LORD
Mr Frequency 32768hz
Post25 Oct 2010, 19:32
Are they Pigeon 4 screw down hatches ?
Post25 Oct 2010, 19:35
It seems to be a lesser common (but not rare) CompuChron.
Not expensive in the ranks of Omega or Pulsar to be sure....
Regarding the pic of the LED display, it looks like one of the digits has some green fuzz growing on it? Not sure if this is just an artifact of the picture itself. If it is fuzz, then that's not a good sign.
1lumhechati
Post25 Oct 2010, 20:04
THANK YOU FOR YOUR RESPONCE.I PUT THE MODULE UNDER A 20 POWER LOOP AND IT'S NOT FUZ IT;S ON THE OUTER DISPLAY AND IS A DROP OF LOOKS LIKE PAINT OR A DROP OF SOMETHING?BUT NOT FUZZ WHAT WOULD I USE TO REMOVE IT WITHOUT SCRATCH THE LED SCREEN?ASLO MAYBE YOU COULD TELL ALITTLE IT,YEAR WHAT MODEL MAYBE,.IT WORKS PERFECT TOO.THANK YOU AND GOD BLESS YOU./MAYBE VALUE. AND WHAT IS PIGEON 4 SCREW LATCHES.I'M NEW TO THIS
JESUS IS LORD
Post26 Oct 2010, 02:01
Try to remove the 'fuzz' with a little rubbing alcohol on a cloth but don't rub to vigorously and take care not to damage anything, normally green deposits are not a good sign as this could indicate damage from leaking battery acid.
Year circa 1975, others might tell you with more accuracy.
(Update: Just noticed the date sticker on the module: Jan '76) :roll:
Value circa $80, although prices fluctuate considerably.
BTW: Your caps lock key appears to be stuck on, lower case is better, upper case is considered to be SHOUTING.
1lumhechati
Post26 Oct 2010, 03:12
Thank you for the data,sorry about the cap's.
JESUS IS LORD
