It is currently 25 Aug 2026, 09:03
seiko a259 - suddenly racing..
james_stan
Post27 Sep 2011, 00:02
Hi all
The seiko I bought about 7 months ago and wearing daily suddenly started 'racing' yesterday - gaining about 2 minutes an hour ! Just checked the battery with my DVM 1.585V so should be good I think.
Any ideas about possible causes/remedies ?
Cheers
James
Seiko Kid
: seiko a259 - suddenly racing..
Post27 Sep 2011, 01:20
Might be the trimmer thats a touch out, or a fault arising in the circuit board?
james_stan
Post27 Sep 2011, 12:45
Hmm yes, I thought abou the trimmer (varicap isn't it ?) but the change was quite big and sudden. Not the slow drift I would have expected.
Cheers
james
Post27 Sep 2011, 13:14
Sounds like the QC is running out of spec.
Did you drop or knock the watch recently ? If the quartz crystal has experienced a shock then this may account for the sudden speed change.
Seiko Kid
Post27 Sep 2011, 22:13
Think Chargers onto something here, on reading the Tech guide it appears that any fault arising in the circuit board could be playing a part in it. You could always try giving it a vinegar / alcohol bath and see if that help clear up any residual circuit board shortages?
I just did some repair work on a A259 and found a cheeky bit of electrolyte damage, was working fine still but I could see it affecting it in the future, maybe you have something similar?
james_stan
Post27 Sep 2011, 23:26
OK thanks guys I'll have it apart at work and put a scope on the QC later this week hopefully.If it's waay out (as in 1-2 mins per hour) Then the scope measure shouldbe good enoughto detect it I hope. Don't recall knocking or banging it although my cycle ride to work can be rather bumpy=> vibrations.
At least that's a starting point...
Ta
JS
