p3 link removal
smokefrog
p3 link removal
Post22 Oct 2011, 02:43
hello all,
how do you remove a link in the p3 (hollow style) link, are they springs pins like the p2?
thanks in advance
gus
: p3 link removal
Post22 Oct 2011, 16:46
Gus:
They spring in, but are not straight pins, generally*. They are shaped like a rams horns, with the two points being the ends that can be pushed in via the side holes. The loop part of the spring-clip(my word) is hidden down inside the hollow link. The thread the picture is from is here:
http://www.dwf.nu/viewtopic.php?t=1968&highlight=capped
*I said generally, as occasionally someone(don't think it's factory), has pulled out those clips and loaded the band with spring bars. It can be done....
Uploaded with ImageShack.us
smokefrog
: p3 link removal
Post23 Oct 2011, 02:30
thanks for the info Ed i will give it a try but first i have to take care of those pesky fall leaves, i know you can relate being a fellow Michigander.
Thanks for the help
gus
