pulsar calculator 901
Post05 Dec 2011, 03:09
after 15 years, i decided for the first time to put some batteries in my pulsar 901 calculator. yeah i know..to many watches and this is not a daily wear watch. I always tough that she was working.
So after putting fresh batts in it..the only thing that works is the calculator. so pressing 0 does the job and all other digits works.
If i press the pulsar command button..the calculator digits goes away and the screen is blanc...nothing anymore..so the command button works but why can i not see the hour or date?
Anyone an idea??
thx
: pulsar calculator 901
Post05 Dec 2011, 04:57
Quartz oscillator crystal died? Not needed for calc. portion.
Post05 Dec 2011, 13:50
yes Ed, that was also in the back of my mind..but how easy is it to repair..i have no experience with this one.
DrLaser
Banned
Post05 Dec 2011, 18:30
Hi to you all
I have a little question on the side . I just would like to know if the calculator modules in the american and european modes are the same .Do they fit each other?
regards
Post05 Dec 2011, 22:28
Yes, all Calculator modules are physically interchangeable. You just have to be careful about re-arranging the keyboard keys to match the version you are installing (reversing the positions of the "C" and "=" keys, and the positions of the "R" and "S" keys, depending on whether a 901 or 902/3 module is going in). DON"T open a Calculator (or any other Pulsar, for that matter) unless you are electrically grounded (or it's a rainy, high-humidity day, to eliminate any possibility of introducing a static charge into the electronics...something that may have killed as many modules as leaking batteries), and NEVER set an uncased Calculator module face-down on any surface, or you can kiss most of the display wire-bonds good-bye. :cry:
