Watch Repair tools
retrowrist
Watch Repair tools
Post11 Jan 2012, 09:55
Hello People,
Just curious, but does anyone know of a company or a jeweler that sells quality watch repair tools? What do you use? Where do you buy?
I am faced with the task of removing the LCD panel from my Seiko M159-5059, and cannot seem to find a slotted screw driver small enough for the task.
I don't mean to bother you guys, but all my camera tools are not suited for watch for watch maintenance.
Any help would be welcomed. Thank you all very much.
- Patrick
: Watch Repair tools
Post11 Jan 2012, 10:19
cobra007
Post11 Jan 2012, 12:29
why do you need to remove the LCD panel?
retrowrist
Post11 Jan 2012, 18:15
Oh yes, I forgot the reason for swapping out the LCD panel...
I need to remove the LCD because the watch I am repairing had a poor polarizer, and the segments were extremely faint . This happens from time to time with early model Seikos.
Originally, I tried to apply a polarizer film (non-adhesive) to the LCD, but this did not work. The extra size of the polarizer film ended up cracking the LCD panel in the far left corner. I eventually found a replacement LCD panel, and need very very thin slotted screw driver to remove the screws. Probably ".08" or somewhere in that range.
Overall, I am in need of some new jewelry tools, and wondered where most people here get theirs.
Anyway, Thank you.
- Patrick
Post11 Jan 2012, 18:41
I buy a lot from these folks. Even their really cheap sets are failry decent they make note that the blades are tempered steel (good). :-)
<<Link removed by request of the website owner>>Hanno
Just for reference, your two smaller common watch screwdrivers are 1mm(.038") and 1.4(.055") - blade size. But that doesn't include screwdrivers for fine mechanical watches. Those go down to .2mm(.0079" :eek: ) - a paper-thin piece of spring steel on the end of thin rod. :lol: Steel that thin is surprisingly stiff.
Post11 Jan 2012, 18:54
Forgot to mention, for reference your panel screws probably have a .5mm(.020") slot. So, you'll want one that small.
THIS is indespensible for resharpening those sizes. What, you think you're gonna eye it? M:)W:)M
This is a much better "life". Thanks you for your courtesy. 8-)
retrowrist
Post11 Jan 2012, 19:04
Thank you ED! And thank you the rest of you guys!
I will try the options you guys gave me.
- Patrick
