It is currently 02 Jul 2026, 08:33
Rayovac RW56 replacements...?
Lillegutt
Post04 Feb 2012, 23:26
I got an old Seiko requiring the RW56 RayoVac battery. These were discontinued as they contained Mercury.
The data is the following:
11.6mm X 3.6mm 1.35V LM
Most batterys listed as replacements are 1.55V while the original was 1.35V. Would it be a bad idea to put a 1.55V battery into a Seiko requiring a 1.35V battery?
Anyone have a good suggestion of a replacement?
I think I might be able to find a Zinc-Air battery with the same data. Are these the only replacements?
JHH
Re: Rayovac RW56 replacements...?
Post05 Feb 2012, 02:03
Du kan bruke 1,55V
Lillegutt
Post05 Feb 2012, 13:54
Takk skal du ha Peter! :-)
Regna med at det gikk greit, men alltid kjekt å få det bekreftet fra noen som har prøvd før.
Seems like a 1.55V substitute will be just fine.
JHH
