What is involved with restoring missing segments...
Majestyk
Post25 Dec 2004, 01:37
What is envolved with restoring missing segments with Pulsar P2 modules? There are no accessible wire bonds with these modules, so is it the entire display that has to be replaced or does it have to do with the row of transistors (or whatever) above the display?
Thanks!
MJ
kc8adu
Re: What is envolved with restoring missing segments...
Post25 Dec 2004, 15:03
if the same segments are out on all digits its a driver issue.
but one out in only one digit is an led/wirebond failure.
Majestyk
Post27 Dec 2004, 02:51
It's the same segment(s) on all the numbers. So I'm assuming the drivers are the row of 7 transistors (as I'll call them) at the top of the display.
How would I remove them and how could I put a replacement in (from another dead module) where the old one was? I'll also have to figure out which driver controls which segments.
Thanks,
MJ
kc8adu
Post29 Dec 2004, 03:27
i would need to see it.
one could test each transistor with a vom.
Majestyk
Post29 Dec 2004, 08:43
Once I localize which ones are the culprit, do they have to be replaced?
Post29 Dec 2004, 14:39
Unfortunately, I don't know what the P2 module looks like.
Can you post a closeup pic?
Is anything printed on the driver transistors?
Are the transistors in a standard SMD plastic package, e.g. SOT23?
If so, they can be replaced easily. Almost any transistor of correct polarity (NPN/PNP) should work.
Does anyone have a circuit diagram of the P2 module?
Majestyk
Post29 Dec 2004, 14:54
Unless someone beats me to it, I'll post a pic shortly, thanks.
Re: What is involved with restoring missing segments...
Post15 Feb 2006, 11:55
Guys!!!!!!
The subject with missing segments has been mentioned at least 3 times on this forum:
http://digital.superman.ws/phpbb2/viewtopic.php?t=1063
http://digital.superman.ws/phpbb2/viewtopic.php?t=982
Detailed pics of modules are shown in the thread above and also on my website:
http://crazywatches.w.interia.pl/photo/ ... _tech.html
embelton
Post15 Feb 2006, 19:03
Azimuth:Nobody digs up old threads like you!
I?m losing my edge!
Post15 Feb 2006, 19:10
:) what's the use in keeping old threads if nobody is reading them anymore. if one thread is already present, then why does the same question appear 3 times.
Post15 Feb 2006, 21:12
Why don't poeple search before they ask?
This question is as old as message boards...
andyz4000
Post20 Feb 2006, 15:25
Azimuth have you ever attempted re-connecting a wirebond to the IC? I have done a few where the wirebond joins to the PC Board with no real drama but the IC looks scary though my little 10x eyeglass :(
Post20 Feb 2006, 16:42
howdy,
I have tried this a few times and have been successful 90%.
This solution works (if you do it properly) on all P4's, Sanyo modules and some Bulova Drivers N7 in which the IC is covered with a plastic plate instead of epoxy. Usually when the same segment is missing on all digits then the IC bonding needs to be checked and repaired.
A microscope can be useful but I did well with a watchmakers 10x eyeglass. It can take a while to get it done perfectly.
seansmiller
Post20 Feb 2006, 23:32
Azimuth, are you saying that you have done repair job on a P4 module with missing secments, and been successful?
I have a P4, 403 DOW module with missing segments:
http://dwf.nu/viewtopic.php?t=1107
I've also asked several other Led-tecs on the web, and they gave me the same answer: It can't be done!
I still have'nt got another module for my Pulsar, and it really bugs the Sh*t out of me :x
If you think this might be fixable for you, please PM me.
andyz4000
Post21 Feb 2006, 00:37
I must try it then, P4 (PC board contact) and Bulova displays are fine and give me no trouble but I have a Bulova single button Driver with 2 wirebonds missing alltogether, the IC on the reverse side of the display is really small so I have shelved it for another day. Man you must have a steady hand, I am making up a clamp and have a miniature lathe part so I can dip the wire in Epoxy and zero in on the IC at less than 0.1 mm progression for a perfect landing, the problem is my 10x makes it hard to see whats going on
Post21 Feb 2006, 10:46
I've got a pretty steady hand as I also work with mechanical watches. However any kind of support for the wrist is helfpul.
In reference to the post by seansmiller a P4 type display might be repaired if only a few segments are missing. If most of them are gone then it's unlikely to repair it. The biggest problem is to remove the display from the module without doing more harm. Very tough job.
andyz4000
Post28 Mar 2006, 13:48
My Microscope finaly came in and its so much better to use, I rebonded a couple of wires on the back of a Bulova Drivers (newer model has a cover). I can bond to the IC by just placing a small amount of bond on the end of the wire and moving in with a mini lathe driver until it touches the contact area.
I did a test run and it works great but the problem is getting very fine wire, the strands I used were a bit too fat.
Pictures of my first attempt, I overdid the first blob but it cleaned up ok.
oldpulsar
Post27 Apr 2006, 00:07
seansmiller wrote:Azimuth, are you saying that you have done repair job on a P4 module with missing secments, and been successful?
It can be done,I have done this hundreds of times!!
Planet-LED
Post29 Apr 2006, 20:06
Andy,
What strength magnification did you use and what brand of microscope? Thanks.
andyz4000
Post30 Apr 2006, 02:22
Post19 May 2006, 13:19
That's an expensive investment ;)
To get an idea of the difference between the early N6 and late N7 Bulova drivers circuit board. The later model had a coverplate:
