It is currently 02 Mar 2026, 02:22
conductive glue or?
conductive glue or?
Post26 Jan 2014, 16:38
i have 2 ladies watches with the same module bit slightly different problem...how can i solve this?
the left one has lost the little small plate to make contact with the case for close circuit..(the small membrane between the 2 modules) how can i fix it?
the right module has a small contact broken off..do i cut a new bigger one and try to bent it a little so it stays there and make contact when pushing or??
and idea's guys?
Re: conductive glue or?
Post26 Jan 2014, 18:00
Could you not just drop a smidgen of solder onto the contact to connect it back together? Or recreate the whole contact a-fresh and solder it back in at the top as per the original?
Post26 Jan 2014, 23:40
i've got one working...now the other one:-)
Post26 Jan 2014, 23:54
Kasper wrote:i've got one working...now the other one:-)......
It must of been a solder fix or you would still be waiting for the glue to dry. :-D ;-)
Users browsing this forum: No registered users and 112 guests
