It is currently 22 Oct 2026, 21:53
...contact "Reset(AC)" point quickly
your_man_in_Hamburg
Post05 Mar 2023, 21:03
Today I opened my Nixon Heat for the first time. There, on the back of the battery clip, was a sticker saying
  1. Replace a new battery
  2. Use metal tweezers to contact "Reset(AC)" point quickly
  3. If it doesn't work repeat step 1 & 2 again
I will not digress and tell you all the things I find amusing or disturbing with this message, but cut directly to my question:
Should the reset point be connected to + or -?
Extra credit:
Why is step 2 necessary? Every other battery powered watch or clock I have experienced up to this point, have started as soon as you put in a new battery.
Re: ...contact "Reset(AC)" point quickly
Post11 Mar 2023, 06:12
I would say connect AC point to the case...presuming it's connected to one side of battery.
When u change a battery, voltage fluctuations/spikes as you put it in and clamp it down can set registers with strange values. I've seen quit a a lot like this...Seikos etc from memory.
