looking for diamant cutting wheel
Post16 Feb 2016, 10:28
ebay number : 171041962437
I need this in a much finer grid and metall bondet, so a diamant cutting wheel between 4 en 7.5 cm in diameter. Been looking for weeks now...anyone an idea?
thx Kasper
rogart
Re: looking for diamant cutting wheel
Post29 Apr 2016, 21:43
Is it something like this you are looking for. http://www.arceurotrade.co.uk/Catalogue ... 520mm-Bore
A round disc with diamonds on the sides.
Smaller then that look in the dental industry?
Post30 Apr 2016, 09:18
No the fine diamond layer has to be on top...so diameter between 2 en 6.5 cm and 0.5 till 1 cm thickness. :-D
rogart
Post30 Apr 2016, 22:49
Something like this but a smaller diameter? http://www.ebay.com/itm/8-INCH-Grit-150 ... 0930389414
Can't find anything smaller then 4 inch?
Post01 May 2016, 16:27
more like this
http://www.ebay.com/itm/150mm-6-inch-TH ... 1786092686
but between 20 and 65 mm diameter and 5 to 10 mm width on top and 3000 grit
Return to Mechanical
