It is currently 22 Oct 2026, 22:52
How to remove this battery clip
P.C.
Post25 Sep 2016, 20:38
I'm having trouble in knowing how to remove the battery clip from a small Casio Casiotron mens dress lcd watch. i cannot see any obvious slots or holes to insert a small pin etc . also not sure which is correct side to 'attack" Any suggestions please?
Re: How to remove this battery clip
Post26 Sep 2016, 15:15
just kidding..take a sharp needle and pull the side metal piece (biggest hole...left on the picture) outward.
P.C.
Post27 Sep 2016, 05:15
Thanks Kasper , that worked! don't suppose you can name to module? I'm having trouble finding the correct method of setting the time, date etc.
Post04 Oct 2016, 22:36
Because I cannot tell exactly the number of the module from Your picture, You may try this (uncommon) setting instructions for an early Casiotron:
http://watches.gafortiby.com/how_to/Cas ... tructions/
Return to Mechanical
