It is currently 25 Oct 2026, 09:57
Cheapskates corner
james_stan
Cheapskates corner
Post18 Jun 2012, 22:25
HI all
Much as I love the Seikos etc (and I really loved the LED Benrus that went for 103 USD this weekend !) I have to watch the
pennies. However it seems you can still pick up a few pieces if you go 'off piste'..
1) Limit LCD (mid to low end brand from the UK) I thought the case might be stainless but now I'm not at all sure
most likely it is not but the plating is good if not as scratches do not show through. Unusual square Hong Kong module by
Elec Art !? with 2 set buttons (although only one does anything :-? ). If you cycle through the right hand set button you can blank display and set date instead of seconds, Heres pics..
Err only somehow the link to Picasaweb does not work :roll: any ideas ? I would like to use this as it's an easy upload
from my Android smart camera-phone.
Cheers JS
james_stan
Re: Cheapskates corner
Post19 Jun 2012, 14:20
Huh - that's odd now I see teh picture :-) - different PC ..
Let's try a pic of the module..
Hurrah !
Post19 Jun 2012, 14:46
maybe check your messages :-D
Post19 Jun 2012, 14:51
Just confirming that the photo's are visible.
The watch has a nice shape 8-)
What function do you think the none working button should have, light? You have probably already done so but it might be worthwhile checking the contact from button to module.
james_stan
Post19 Jun 2012, 19:44
kasper wrote:maybe check your messages :-D
Aha - not magic after all ! Thanks Kasper. I hope I also figured it out now. :eek:
@ Bucko - I figured it out the second set button is err, used for setting ! Didn't need to try it before as the seller set it correctly :oops:
Cheers
JS
Post20 Jun 2012, 11:38
Interestingly shaped watch! I guess it doesn't have the light then. I like the band too! ;-)
