It is currently 06 Mar 2026, 00:39
Never ending word association. Strictly for fun!!
: Never ending word association. Strictly for fun!!
Post17 May 2009, 16:51
VOMIT :~#
Snetzka
Post17 May 2009, 22:16
BUCKET.
(We have all been there at one time or other..!)
Post17 May 2009, 23:52
SPADE
Snetzka
Post18 May 2009, 01:44
SHOVEL.
Post18 May 2009, 04:32
Post18 May 2009, 09:29
DIANA
Post18 May 2009, 15:11
PELLET
The ultimate in airguns, sold under the "Diana" name in the USA...German made.
http://www.airgunsus.com/desc/rws16155.html - worth every penny I paid for it, will usually put a pellet through 1/2"(12.mm) seven-ply plywood at 30-ish yards/meters.
Post18 May 2009, 20:02
Snetzka
Post18 May 2009, 21:45
MICROWAVE
Post19 May 2009, 00:13
RADIATION
Snetzka
Post19 May 2009, 01:18
SOLAR
Post19 May 2009, 02:34
WIND
"Solar Wind" is a favorite(of mine) all instrumental LP by Ramsey Lewis...never remastered to CD unfortunately.
If you like jazz, this has a nice vibe for a summer day...
"Jamaican Marketplace" http://www.dwf.nu/images/jamaicanmarketplace.mp3
Snetzka
Post19 May 2009, 03:22
THING
Snetzka
Post19 May 2009, 03:47
Post19 May 2009, 05:47
OWL
Snetzka
Post19 May 2009, 05:57
BARN
Post19 May 2009, 20:04
RED
Remembered from an old school project............
http://en.wikipedia.org/wiki/Red_Barn_Murder
Post19 May 2009, 22:17
LEAD [a red lead based paint used under the battleship gray as a primer on ships]
Snetzka
Post19 May 2009, 22:52
SOLDER
(Soft Solder to be exact.) - A 60/40 mix of Tin and Lead used in the electrical and plumbing industry (Plumbing tend to use 50/50). Until the 'good old' Europian Union and ROHS stepped in and banned the use of lead.!
Post20 May 2009, 00:30
BRAZE
from wikipedia...http://en.wikipedia.org/wiki/Brazing
Brazing
Brazing has historically been defined in many ways and is often confused with soldering. A defining characteristic is that the braze melts while the material(s) being joined do not. The distinction between brazing and soldering is somewhat arbitrary; brazing occurs at a higher temperature than soldering. One definition of brazing is “joining of two materials using a third, dissimilar material at higher temperatures than soldering.” While the exact temperature difference between brazing and soldering is often disputed, there are definite metallurgical reasons to use the 450 °C (840 °F) figure. This is the official American Welding Society definition.
Braze alloy is often used to define an alloy that flows in thin joints while braze filler metal is used for thicker joints and for gap filling.
Snetzka
Post20 May 2009, 03:52
WELD
Welding is a fabrication or sculptural process that joins materials, usually metals or thermoplastics, by causing coalescence. This is often done by melting the workpieces and adding a filler material to form a pool of molten material (the weld pool) that cools to become a strong joint, with pressure sometimes used in conjunction with heat, or by itself, to produce the weld. This is in contrast with soldering and brazing, which involve melting a lower-melting-point material between the workpieces to form a bond between them, without melting the workpieces.
http://en.wikipedia.org/wiki/Welding
PreviousNext
Users browsing this forum: No registered users and 97 guests
