It is currently 25 Sep 2026, 09:07
What is Profectus!!???
markyd3
Post17 Oct 2010, 13:39
Ok so Im just starting to collect a few LED watches as this site has got me back into them lol....
I have just bought this one for $30
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... K:MEWNX:IT
Seller has said i can have a refund if it doesnt work which is good :-)
Anyway I just wanted to ask if anyone knew what Profectus was as it states it has a "Profectus Plated" bezel!!!
A quick search on google didnt really tell me much other then that Heuer watches used to use the same material in the 70's!!
If it works it cant be bad for £25 inc shipping :-)
: What is Profectus!!???
Post17 Oct 2010, 16:21
Neat watch. Apparently, the Latin translation for "profectus" is something akin to "advanced":
http://www.myetymology.com/latin/profectus.html
We live on an age where "advanced" is used as a marketing synonym for "good", without specifying what exactly is advanced or why it's better. So, not everything has changed since the 70s.
J Thomas
Re: : What is Profectus!!???
Post17 Oct 2010, 16:48
:-D
Post17 Oct 2010, 17:56
The modules in these type of Armitron's are bullet proof the best I've come across, the display is totally enclosed in plastic battery corrosion has to be very severe to stop these things from working.
Be careful installing new batteries though the positive & negative are usually not visible on the PCB look for a tapered edge on one battery well this is the negative contact the battery is inserted with the plus facing outwards.
Good looking watch, well done... :-D
markyd3
Post17 Oct 2010, 18:06
Cheers Guys!!??
Im assuming that Armitron were a relatively cheap watch back then but ive not seen too many of them advertised on ebay...
Now... anyone in the know enough to tell me what cells it will require...lol ive got plenty of LR44's and SR44's now but i bet these will be too big!!!!
markyd3
Post02 Nov 2010, 14:43
Well...... another watch that doesnt work!!!
Anyone got any tips or tricks i can try to get this fired up?
When i received the watch there was some ancient RW25 batteries in it which had leaked badly so i cleaned up all the contacts with my little fibreglass pen and still nothing :-(
Post02 Nov 2010, 21:59
Post a pic of the inside of the module so we can have a look.
markyd3
Post02 Nov 2010, 23:31
Here you go...
Post04 Nov 2010, 01:17
Ok, remove the module from the case and carefully prise the plastic carrier off then we can see how bad the corrosion is, it may just need a replacement trimmer and quartz crystal, after a good cleaning that is.
markyd3
Post04 Nov 2010, 01:29
Klippie wrote:Ok, remove the module from the case and carefully prise the plastic carrier off then we can see how bad the corrosion is, it may just need a replacement trimmer and quartz crystal, after a good cleaning that is.
do i have to lol..... cant i just soak it in vinegar!!? :-P
Users browsing this forum: No registered users and 106 guests
