It is currently 07 Oct 2025, 08:08
Pulsar Timing chip
embelton
re: Pulsar Timing chip
Post17 Feb 2007, 16:51
I´ll be whatever you want me to be :roll:
I?m losing my edge!
Planet-LED
Post17 Feb 2007, 18:19
Phil,
So are you simply soldering in a jumper wire to connect pins 5 and 8 together?
leddwatch
Banned
Post18 Feb 2007, 00:16
errr, no, definately not! When the heat variable resistors break down that Ive shown in the diagram and pictures above, these are oscillator components and will cause an oscillator failure, what Im saying is that if you replace them with resisitor of known values you can get the watch to run. This is something for experienced electronic experimentors to try because it takes some micro-soldering and experimenting to achieve, but once you figure it out the first time it gets very easy to do again.
Planet-LED
Post18 Feb 2007, 01:38
Phil,
Thanks, I understand now.
Previous
