21 May 2007, 02:44
Silicone won't stick to vaseline(learned this via mold making), so.......
Coat button with light layer of vaseline(warm button, drop in vaseline, pull out).
Stand up on a piece of paper or aluminum foil which also has very thin layer of vaseline on it and throw in freezer for 10-20 minutes - this will keep it from dancing around on you and freeze it to the paper/foil.
Using high-temp silicone(reddish/gold...often sold where double or triple wall chimmney piping for fireplaces, is sold), make a nice ring around it.
Let dry, trim to fit, it will easily survive 450-480 degrees farenheit, which is what it takes to melt solder.
You could try to grease both case and button to make a "custom fit", but it is more trouble than it is worth. A sharp razor and a steady hand can do quite a nice job of this... a little trial and error the first few times.
Myself, I lock a flat piece of steel(actually a tool steel for a lathe) sticking sideways out of the bench vise, stack the cap and other parts on it, heat the case with a butane pencil torch(take glass out, this is very easy) and push the case down on the button pack. Tip it gently to the side, flip over and you can push it a little more with something - use wood or something brass...a screwdriver tip can make a ding in the cap which will screw up the function.
Alternate methods would be great to hear about.
"There is more than one way to skin a cat?" 8)
http://www.retroleds.com -
Sales of vintage LED, LCD, analog watches,
parts and gadgets -
repair tutorials & tips
