02 May 2014, 22:48
According to the best information I have, the Pulsar modules go like this:
P1
201-1 (single trimmer, horizontal light sensor)
201-2 (dual trimmer, vertical light sensor)
P2 Same as P1
P2/Date 301-3 (very rare 305 exists; displays Date same as Time, for 1.25 seconds)
P3 301-3
P4
401 magnet set, all models
402 Auto-Set, all models
403 DOW display, Big Time and Classic only
406 24-HR display, Executive only
Dress
102 Magnet set, all models (large LED digits)
104 Auto-Set, all models (large LED digits)
110 Emerald Green display, 3416 only
501 Touch-Command, Auto-Set (magnified LED digits) 5503 only
502 Touch-Command Auto-Set, Auto-Command (rare) 5503 only
Men's Sport 501 Auto-Set (502 will work in 3502 case)
Ladies Pulsar
101 Magnet-set, all models (small LED digits)
103 Auto-Set, all models (small LED digits)
Calculator
901 No DOW or Auto-Command
902 DOW display, Auto-Command
903 DOW display, Auto-Command (second flick gives Date; rare)
Pulse-Time 910
Ladies' Touch-Command 801 All models
The original E/D P1 module may have been designated the 200; I'm subject to correction on that. The only physical difference among the Dress and Ladies' Pulsar modules (101-104) is the size of the digits; there is a very rare bar-segment display variation, but the module functions the same, and is not a separate model). There are digit-height variations among the P4 and Dress modules, but the smallest of them is still larger than the Ladies models; presumably, the displays were coming from different manufacturers (for example, the P3 modules come with two distinctly different LED displays, one by Litronix, the other from Monsanto). Finally, there is a very rare dot-segment display that is found on a few of the early Limited Edition (first 100) 18K Calculators. On the 4300, I have both Ladies' and Dress modules with the 4300 plaque on them, and without it. On those with it, there is a raised line that defines a "pocket" to allow the plaque to be mounted in a specific position; this feature is missing on the modules without the plaque, so, clearly, two different injection molds were used (green carriers seem to have been made only in the no-plaque version).
This doesn't seem to indicate any special effort by Time Computer to create some sort of color-coded identification system for the modules; rather, it looks just like random assembly of parts. The specific significance of the 4300 designation is open to speculation; all P4 modules seem to carry a similar plaque with the number "4000"...probably a reference to the 400-series of modules.
No doubt this post will be edited several times as new or updated information becomes available.
bruce wegmann on 03 May 2014, 21:22, edited 3 times in total.
