Touch command
CompuChron
Touch command
Post19 Jan 2008, 00:18
I have a ladies Pulsar touch command on which , the upper "button" doesn't work.
Where should I begin to look at?
: Touch command
Post19 Jan 2008, 06:13
1.Take module out.
2.Since it is winter and your skin may be dry - go wash you hands(seriously).
3.Put two batteries into module and carefully line up back with two batteries, as if module were in watch.
4. Now, since your body is touching the back while you hold the backon, you have the first part of the neccesary electrical connection made. Take a finger from other hand and touch contact at top(front of module - it should light. If not, try bottom contact - if it doesn't light, you are doing something wrong. Re-read instructions above. :-?
5.If it lights when you touch top contact, then your problem is merely a bad contact/connection between the module and the small "nipple" of the button that is supposed to touch it. Caress the "nipple gently" - I mean clean it gently. :lol:
6. Clean module contact gently - you might elect to bend it outward the smallest amount. Be sure to use two tools, one to support the part of the contact you are not bending - bending it without grabbing it right before the module is asking for it to be BROKEN off the module. But see if cleaning helps before bending.
7. You can put the merest trace of silver bearing grease on the "nipple" or you can put a small amount of silver bearing epoxy on it but only use one part of the epoxy - in other words don't mix the two parts "A" & "B" together!! Just use either part "A" or "B". You don't want to glue your watch together! One part by itself will merely get gummy - it will easily clean off with alcohol even years later.
Godspeed and good hunting!
:idea: A suggestion on silver epoxy - if you store the tubes upright the silver will settle away from the tip and you will mainly be blobbing out silver colored epoxy base for first 2/3 of tube, then it will generally clog. Stored the other way it will expend a large portion of the silver during first 1/2 of tube, then just puke out silver colerd epoxy base....if it hasn't already clogged and totally pissed you off. :x Find two small glass jars(like model paint comes in, or artists store mixed tints in) and cut the entire top off your new epoxy tubes, squirting every bit of it into their respective jars. Whenever you use it, give each of the two parts a quick stir with a clean toothpick or such. You'll alway have a consistent mix of silver to base and your epoxy will go incredibly far, since most repairs only require the smallest drop. You can use your stirrer to dip out the small amount you need.
At $25-30 for a pair of 1/4 ounce tubes, it can get expensive if you use much of it. :cry: And the more consistent results are priceless.
CompuChron
: Touch command
Post19 Jan 2008, 21:08
Thanks Ed, very clear answer.
The watch is repaired now , I had to solder the contact, but my solder was a little big and touched the case so it lite up the display all the time.
I put a few mm of tape on it and everything works great now.
I don't know what to do with a ladies Pulsar, without band, I think I'm gonna put on the dash of my car where I need it.
I bought a watch from njhighlight on ebay and he gave me that Pulsar watch as a surprise;
Nice?Not so much because I bought a "working mens LED" "but bid as it wasn't working" and guess what?It wasn't working when it arrived.
I suspect greatly that he knew his watch was a piece of shit and as I paid top price for a non worker , he gave me that Pulsar...
