Charger:
Sorry I was so brief, we had a tornado pass thru this area and I've been without Internet or phone for 4.5 days(back on last night), power via whole-house generator. I was reducedb to using my stepdaughter's laptop from a WI-fi connection point while we out shopping(the ladies shopped, I used the laptop
Anyway....I'm thinking you might be getting higher resistance readings as the sensor secotion may have already deteriorated somewhat. I pried off 5-6 of them to find the three best looking ones, and then was drawing an average of my readings. Some modules that are only lightly acid burnt will have almost no trace of the sensor under the IC, completely dissappeared in other cases. The trimmer needs to be in the circuit for it to work, the capacitance is fairly critical and within a narrow range. E.G. If you accidentially buy 18pf quartz oscillators instead of the correct 12pf., you will find few modules that will show any life. The more we go into this, the more I think it was a really bad idea to have that exposed sensor under the IC. I've often wondered about the exposure of the IC leads under the IC and how much failure is due to them being exposed to light acid or shorting out from fairly minor dust and such such. The longest living modules, over all the manufacturers, seems to be the ones that are/were sealed the best. I currently seal over the wire bonds of any and all modules that wasn't sealed at the factory. $.10 of slow set epoxy means never having to say, "darn, I just clumsily ruined a perfectly good module.".
Keep plugging away at it...and don't be put off by the lack of commentary. At this time of year forum participation typically falls to a low point as people enjoy the nicer weather in the northern hemisphere. 95%+ of our members live in the northern hemisphere.
http://www.retroleds.com -
Sales of vintage LED, LCD, analog watches,
parts and gadgets -
repair tutorials & tips
