Short of pulling the module apart...some ideas.
1. Be sure battery contacts are clean.
2. While gently pushing in, rotate each of the two spring which stick out of back of module several times. Basically you are trying to get the end of the spring to clean a spot on the aluminum contact area it touches, without having to open things up.
3. And you understand the back must be on for it to operate? No offense intended.
