It is currently 23 Apr 2026, 16:41
Pulsar 901/902 manual
Post25 Jan 2012, 21:45
Looking for a manual or scan of a manual for the 902/902. If you have a spare I will scan it and send it back.
Just acquired a 902 with intermittent calculator so hoping a disassembly and cleaning will get it up and running. Clock works. Have a 901 with two wire bonds broken, otherwise functioning correctly. Did a thorough clean and deoxit to get it running. Unfortunately there was some silver epoxy from a bad repair attempt on the traces for the defunct wire bonds. Hanno couldn't wire bond unless the epoxy is removed so I WILL remove the epoxy!
Cheers, all.
Let me know about an original spare manual, as I said, if I get a good one on loan, I can scan it, photoshop out imperfections and send the original back. I would then post the results here.
