It is currently 23 Apr 2026, 15:13
What type of glue is used on the battery wings?
Mister Tawny
Post23 Sep 2012, 18:30
The things that are attached to the back (I call them wings) have come undone on my P2. I see there was sticky stuff holding it on, but it has let go. What should I use now to fix it?
My collection:
Pulsar P1, P2 Date, 3 P3's 2 in SS and one in 10K GF, Gent's dress in SS
6 Bulova Driver's watches 4 in 10K GF and 2 in two tone
Majestyk I and II
3 Vostok military watches
Poljot 3133 Chronograph
Wakmann Valjoux 730
Tudor 7934, 7802
Accutron A26B35
Seiko Sports 50
Benrus Oval
Hamilton Savitar II, Pacer and Ventura
Orient Star automatic
More to come...
LED
Re: What type of glue is used on the battery wings?
Post23 Sep 2012, 23:27
The official name is "bow tie" contact :lol: and the official recommendation is cyan acrylat glue to it. But you may as well use two component epoxy.
Post24 Sep 2012, 15:52
Don't use epoxy - most will come off. Epoxy is great but there is too much flexing of the bow-tie. Pulsar engineers and hundreds of repairs would agree on this.....they had epoxy, they knew it would suck.
Suggestions on re-attachment. Every case back has two small dimples/markes that are supposed to line up with the two holes in the bow-tie. Clean back and bow-tie very well. Then put a small black dot in each of the dimples with a fine tip marker. One small drop of gel-type SUper GLue/ cyanoacrylate, carefully place the bow tie over the dots, position and hold down with a wooden toothpick, not your fingers. With good lighting you can see you black dots through the holes in the bow-tie.
Basically I have just restated pg 10 of the Pulsar Jeweler's Technical Manual available http://retroleds.com/pulsar-jewelers-technical-manual/ as well as other places. :lol:
