Please don't forget to write your location in the profile, so we know where are you from!
With a replacement of the quartz crystal, the watch might work again, otherwise the solution to resurrect it is to convert the module to a SASM one.
You can to talk to our administrator Hanno (SASM) at StrikesAndSpares , he can make a SASM module out from your old one. A SASM module is made with the parts of your old module (display, light sensor, reed switches, plastic carrier and the quartz crystal -if it's not faulty, otherwise that part is replaced as well-), to ensure the maximum compatibility and the same look-and-feel of the original module: it'll look and work exactly like the original module, without any visible difference, except for the "SAS" sign appearing for a second when you change the batteries, that shows the module is a SASM one. A SASM module is the best way to make your Hamilton work again. It's reliable, has a lower battery consumption and it has a one year warranty.
