It is currently 29 Jul 2026, 23:22
T-C-2 setting instructions
Colin G
Post09 May 2007, 22:36
Anyone give me a link to these or give me a quick run down?
It's ages since i've done it and can't find my set
re: T-C-2 setting instructions
Post09 May 2007, 23:00
Hours and minutes set directly with the magnet. To set month, press DATE button and place magnet in HR recess. To set DAY, press DATE and TIME buttons simultaneously and place magnet in HR recess. Date will advance and AM/PM dot will cycle up and down. Remove magnet when display and AM/PM indicator are correct. You can reverse the AM/PM indicator without changing the date by running the HRs foreward 12 hours. Instructions apply to Pulsar P3 models also.
Colin G
Post13 May 2007, 20:01
Thanks Bruce, it seems I have a problem with it.
Colin.
Post14 May 2007, 01:04
What's it doing [or not doing, as the case may be]? Damaged switches or weak magnets are the usual culprits here...
Colin G
Post14 May 2007, 23:25
It will not set the date or month....I've switched magnets but still nothing, any ideas?
Post15 May 2007, 04:32
Does it set the hours? Does it display the date? If it shows the date, and does set the hours, there is probably a logic defect in the clock chip. Otherwise, the problem is a bad switch.
Colin G
Post15 May 2007, 10:58
Bruce, it displays and sets the hours ok, displays the date and month but will not set them, they are frozen.
Colin.
Return to Omega and GP
