It is currently 28 Jul 2026, 17:47
Question to TC II
danny1707
Question to TC II
Post26 Jun 2012, 21:13
Hi all,
I recently bought an Omega Time Computer II.
The problem I have is that I can not set the minutes. If I put the magnet to the "MIN" slot the watch shows shortly the time but then jumps directly to the seconds and displays them continuously.
The minutes does not change.
I can set the hours and date and month without a problem. I tried it with an original Omega magnet and a second different one.
Is that a defect of the watch or does anybody have an idea or trick for me?
Thank you very much.
Best Regards,
Daniel
Re: Question to TC II
Post26 Jun 2012, 23:38
The magnet is activating the reed switch for the time/seconds display. Try experimenting with the position of the magnet, twist it around, spin it upside down, move it around on the case back, try a different magnet, there is normally a sweet spot which when found will advance the minutes but it can be tricky to find.
Good luck and welcome to the forum.
Seiko Kid
Post15 Aug 2012, 16:58
just has the same with one, I found that if you dont put the magnet too close it works just fine
Return to Omega and GP
