It is currently 23 Apr 2026, 16:35
Light LED
Firefly
Light LED
Post21 Nov 2008, 22:10
Hi
Why i can see time in the dark and not in the light? the brightness led reduces that I am closer to the light :eek:, it's a synchronar MKI
Synchroserious
: Light LED
Post21 Nov 2008, 23:11
Hmm, sounds like you have bought a bad replica that someone cobbled together.If the solar cell is not connected it would remain in low intensity mode no matter what light condition and be difficult to see in bright light.
Also this most likely means it is not able to charge. :cry:
Firefly
: Light LED
Post26 Nov 2008, 17:30
YES YES YES YESSSSSSSSSSSSS!!!!!!!!!!!!!!!!!!!!!!!
My SYNCHRONAR MKI work i find why the light reduce when i put it under light, i changed the diode and moved the polarity SC and is recharge battery.
ALL WORK!!!!!!!!
Ps: i can set: hour, minutes, day but i can't for the month why? :-?
Sully008
Re: : Light LED
Post26 Nov 2008, 18:10
Firefly wrote:YES YES YES YESSSSSSSSSSSSS!!!!!!!!!!!!!!!!!!!!!!!
ALL WORK!!!!!!!!
There doesn't seem to be an easy way to set the month on a MkI/II module. See this thread for tips:
http://dwf.nu/viewtopic.php?t=2913
I haven't set the date on my Sunwatch yet either.
: Light LED
Post26 Nov 2008, 23:40
i don't think there is an easy way to set the month. not only do you need to set the correct month, you need the right year of the leap year cycle to get feb 29. what i do is set the date to the last day of the month[whatever month is showing] and let the watch change at midnite to the first of the next month. reset the date to the last day of that month and let the watch reset at midnite. keep doing this until you get to the right month and set the date. if you want to set the leap year cycle, you need to keep doing this until with a reset of feb to 28th it changes to 29th at midnite. now you are on the leap year, feb 29. this year 2008 is a leap year. if you have the time to do it, you can also reset the time to 23:59 each time and wait 1 minute for the date to change. i found this to be toooo tedious. peter
Firefly
: Light LED
Post27 Nov 2008, 11:35
I can't see the leap year cycle because when i choose second display i see 0:25 for example not the leap year, i have 6 magnetic reed, with your explication i can set month but it's very long ;*
CRAP!!!! Arggggggghhhhhhh my SC is broken :cry: HELP ME
Synchroserious
Re: : Light LED
Post27 Nov 2008, 18:09
CRAP!!!! Arggggggghhhhhhh my SC is broken :cry: HELP ME[/quote]
The solar cells used now are much less brittle.It is diffucult to remove the old type without breaking them,mostly because of how much they cling to the Gel.
However, I strongly do not recomend installing them with the tiny factory wires.The ones i use and will list for sale at the market place section have larger (30 awg) tin coated copper wires(2 + in front,1 - in back) installed.
Just another Thursday to some, but Happy Thanksgiving to all.
