It is currently 19 Jan 2026, 04:55
Fixing up another Synchronar... What was I thinking?
J Thomas
Post21 Oct 2009, 19:12
:-D
: Fixing up another Synchronar... What was I thinking?
Post22 Oct 2009, 09:38
Those MkIII/IV scrapers are certainly riehl hard to work on. Out of 5 or 6 lots I've only got 2 going. I try to make sure there's an encapsulated IC amongst them, which invariably do work. He doesn't seem to have these any more though.
Get yourself an unopened MkI/II. I'm sure you'd get one of these fired up in no time.
Post22 Oct 2009, 14:18
Use the original displays and cases to build "Syncronar clones" with a newly designed module...
J Thomas
Re: : Fixing up another Synchronar... What was I thinking?
Post22 Oct 2009, 21:50
:-D
Sully008
Post22 Oct 2009, 22:04
The trick with Barry's auctions is to wait for one with boards that have alot of parts still attached to them. That one listed looks like there might be 3 with everything but a solar cell. Most of those boards look like the resistors were pulled out of them. I lucked out and won an auction that looks like it has 5 boards with everything but a solar cell. Sometimes ones that are still in the red bottom only need a new S/C and batteries.
In one batch of MkI/II boards I bought I had one with a display that was bent at a 45 degree angle, green fuzzy traces, and missing a QC. But when I put power to it, segments lit up. Added a QC and voila! It was working! Carefully bent the display back to perpendicular added an SC and put it in a case. I even figured out how to fit the bloody V80s in flush. Mess around with these long enough and you're bound to get it right.
Post23 Oct 2009, 00:02
well there you go mike! i have afew i have been messing with off and on for a year now and they are still not quite right. i think some of these ARE beyond repair. :eek: :-( jeff, since we are only a few miles apart, maybe we should put our heads together sometime? peter
Post23 Oct 2009, 17:51
J Thomas wrote:
rewolf wrote:Use the original displays and cases to build "Syncronar clones" with a newly designed module...
.... I'm afraid it would never pay for itself as a project. .....
Certainly not if you have to pay for it. But as a hobby project it'd be nice.
J Thomas
Post23 Oct 2009, 18:56
:-D
J Thomas
Post23 Oct 2009, 19:24
:-D
J Thomas
Post05 Nov 2009, 18:13
:-D
