It is currently 19 Jan 2026, 04:51
Charging Day
Charging Day
Post17 Oct 2010, 03:31
Hi All.
I like to recharge my Synchronars every now and then. I layed them out on the back lawn and thought they looked so good I'd take a photo. So, here they are:
: Charging Day
Post17 Oct 2010, 05:08
Aahhh...They look ripe for the picking :O`~
Nice weather, the Synchronars are in full bloom!
J Thomas
: Charging Day
Post17 Oct 2010, 06:20
:-D
: Charging Day
Post17 Oct 2010, 07:15
Nice patch of Synchs. I wish a little patch of Synchs would sprout up in my yard. What are you using for fertilizer?
: Charging Day
Post17 Oct 2010, 07:54
Thanks guys.
Yes Jeff, they're all covered. Left to right there's:
SS MkIV
Black ceramic MkI
SS MkIV
Gold-plated MkIII (Synch module in Sunwatch case)
SS MkI (the only one I regularly wear)
Flat cornered MkIII Sunwatch (flat-top module)
At the back are a MkII module and a MkI module.
I've run out of cases for the modules. I've got a flat-cornered Synch case to put the MkII into, but it seems to have been mis-cast or mis-milled. I just can't get anything to sit right in it.
Abe, I find that blood sweat and tears is an excellent way to get them to sprout (literally !). I've spent far too many hours tinkering with these things, but I've learned a lot and enjoyed every minute.
: Charging Day
Post17 Oct 2010, 12:26
:-D 8-) :-D 8-) :mrgreen:
: Charging Day
Post18 Oct 2010, 01:44
neat collection andrew. on the flat corner top. i have one that did not fit anything well either. i used a diamond tip burr in a flexshaft grinder and ground out the inside area that didn't have enough clearance. i believe that howard told me the flat corner tops weren't used on the mkI/II's and that is why they don't fit well. i have mine on a mkII red top. it is snug, but it fits nicely. just thought i would mention that so you may want to see just how much it is off. peter
: Charging Day
Post18 Oct 2010, 08:45
Hi Peter.
I think you're right. The flat corner cases only seem to have been used with the MkIIIs.
I've tried grinding a damaged lexan top in an attempt to identify where it's not fitting properly. No luck yet. Once I've identified the problem area, I'll try your method to adjust the case.
prasarn
: Charging Day
Post03 Nov 2010, 08:13
J Thomas
Re: : Charging Day
Post03 Nov 2010, 15:32
:-D
prasarn
: Charging Day
Post04 Nov 2010, 06:59
oh no it just may be black zinc case and repaint black,and rubber strap from amida digitrend.but it look smart ~:(
