It is currently 28 Jul 2026, 14:22
sanyo module watches
holly35
Post06 Jul 2007, 18:36
any info on what watch makes used sanyo led modules?quality? compared with huges? reliability?
what is the setting procedure on them? pusher at 1 oclock and 8 oclock with 2 setting buttons below the 1 oclock pusher.
i believe comuchron used them and dugena are they better than the huges examples?
: sanyo module watches
Post07 Jul 2007, 00:19
Sanyo, Compu chron, Chronosonic and Baylor (so far as I know).
They rock. If I had to find one minus point it'd be that the IC doesn't have much protection from battery leakage.
They set the same as a P3 (Pulsar). Press the buttons instead of using a magnet.
The Hughes hasn't got a light sensor. Other than that there's not much in it. (apart from the 26mm hughes modules which I try to avoid).
Just curious. Why are you asking?
holly35
Post15 Jul 2007, 19:47
i already have a huges module version and have recenty purchased a sanyo module compuchron.
Handy
Post18 Jul 2007, 00:23
I've never had anything with a Sanyo module but I must admit, they do appear to be nicely made. :D
