duel timezone NS module
Post15 Oct 2006, 23:55
Does anyone know how to set the extra time zone on the national semiconductor duel time zone module. I think it's the same module as the one in the tasty Novus that Little1up has up for auction at the moment.
Mine starts up at 1pm so I can set it by staying up really late and putting the caseback on at exactly the right moment - but I'd rather use the setting switch (which appears to just set the local time button).
Re: duel timezone NS module
Post16 Oct 2006, 01:35
digibloke,
I take it you want to set the time using the left button.
I've just checked this out for you on my Benrus duel time, firstly press the set button to display the hours, then press the left button to set that time zone, next press the right button to advance the hours, finally press the set button again to return to normal function.
That should be it.
Hope this helps...
Post17 Oct 2006, 09:29
Thanks Klippie. That was pretty much the only combination of button pressing that I hadn't tried...
