It is currently 23 Jun 2026, 21:34
Looking inside a Sunwatch
J Thomas
Post29 Jan 2008, 21:37
:-D
Synchroserious
: Looking inside a Sunwatch
Post30 Jan 2008, 21:12
Hi John, Did you get my PM ? I can answer all your questions here tomorrow,just need to confirm a few things.
Howard
Synchroserious
Post31 Jan 2008, 21:36
Is that a broken reed switch under the QC ? Sounds like you may need to use a small amount of solder or small wire to fix traces on the board since you have concluded there is an open circuit trace from + PV leading to positive on the battery,check thru hole area and put a drop of solder in the hole.Very carefully you will need to clean the area around the QC and resistor and get all goo or finger oil removed while keeping the isopropyl alcohol and brush from getting near the chip area,wait 30 min to dry.You may even need to replace the QC. RTC did things different and the greater majority of MK III circuits did not have a chip in package.The one you have was originaly a Sunwatch but a Synchronar top would make it a Synchronar module.That is the only difference.The PCB like that is from 77-78.There was 5 different PCB,s used just for the MK III.I have a bunch for someone to sit down and test.I find one that works and build it anytime an order is placed.
Synchroserious
Post31 Jan 2008, 21:50
I just got your PM, I guess the world is not that small and your name is not John :oops: I built a watch for a John Thomas awhile back,sorry for the mix-up.
J Thomas
Post31 Jan 2008, 22:50
:-D
Synchroserious
Post01 Feb 2008, 17:47
You are welcome. Just noticed your nixietube post.Before i even began reading it dawned on me you are the guy that developed the nixie tube watch.
dot matrix
Re: Looking inside a Sunwatch
Post22 Jan 2010, 00:07
J Thomas wrote:I have an inoperative Sunwatch, and so I opened it up to replace the two cells with hopes of getting it working.
The case was a bit of a challenge to open, but it did open up without damage to either the top or the black bottom. From what I've heard, these are a real pain to open without damage.
May I ask what technique you used to open it?
J Thomas
Post22 Jan 2010, 19:03
:-D
