It is currently 07 Oct 2025, 15:20
Hughes 25mm Programmable Module?
Post01 Oct 2010, 20:36
Did Hughes make a 25mm programmable module?
I had a look through my junk box of bits and found a Hughes 25mm module, I tried it with batteries and it lit up but not correctly, some segments where very bright some dim, I went through the set procedure and found that it scrolled through the alphabet on each of the 5 digits as per the 29mm Hughes programmable module. Once the set procedure was complete the module displayed a sequence of 5 lots of random letters on the third press of the command as if attempting to display a message.
I have only ever seen a 29mm programmable module, have I missed this one?
: Hughes 25mm Programmable Module?
Post01 Oct 2010, 20:41
Maybe it was an escapee from the programming room.
"They can't make me talk". :x
Post02 Oct 2010, 00:12
"They can't make me talk".............more than 5 words with a maximum of 5 letters per word that is :lol:
